HELP!!! 2004 GMC Yukon Xl Denali 6.0 intake noise
Thank you for your input!
Actually, I took out the intake, replaced the valley gasket, put in the new knock sensors, new harness, and sealed it up this afternoon. You said it should take 3 hours, but that is as far as I got in the 3 hours. lol
I was having a hell of a time with the throttle body coolant lines and I ended up just leaving them attached and removed it from the intake)
I will clean up the intake and get it back on this weekend and see how it runs then.
Thanks again!
During disassembly did you see anything that would have caused the problem you are experiencing?
^^^THIS!! Such a noise from an intake leak would surely be from an obvious source.
kaysha241
kaysha241
Phoenix az
No, I didn't! Unfortunately, It is still having the issue. I haven't been able to work on it in the last week and a half. Im working on eliminating MAP sensor, and will look at CAT converter and possibly fuel injector. Not sure what else to check.
Otherwise...It can go to the shop and a real tech can look at it.
kaysha241
kaysha241
Phoenix az
Ok...so I unplugged coil packs one by one and the fuel injectors... no noticeable change in idle. I took out the upstream O2 sensors and no noticeable change. Fresh air filter, MAP sensor, still no change...
I'm at a loss...I guess it will go to the shop to be diagnosed.
kaisin
