Prospect62
Well, after cutting and splicing on my factory exhaust way too much, it's finally starting to give up. Since I bought the truck in January 2020, I've fiddled with the OEM "norma" clamp and never gotten it to seal right, I've had aftermarket mufflers welded in and cut back out, I've had my "flexy" pipe completely blow apart. Most of the welds done by hack the muffler shops have corroded and are leaking (New York salty roads+crappy welds).
I just put a new transmission in this thing ($5000 later) so it looks like I'll be keeping her for a bit longer than planned. The exhaust is leaking to the point I can smell it in the cabin and I've decided it's time for a whole new cat-back system. Here's what I'm considering:
Gibson single: https://www.summitracing.com/parts/gib-615637/make/chevrolet/model/suburban/year/2016
Gibson dual: https://www.summitracing.com/parts/gib-65687/make/chevrolet/model/suburban/year/2016
MBRP single: https://www.summitracing.com/parts/mbr-s5043304
Corsa single: https://www.amazon.com/Corsa-14748-...f7-5c5b21200257&ref_=pd_gw_ci_mcx_mr_hp_atf_m
Borla single (dual tip): https://www.summitracing.com/parts/bor-140558
All of these are the stainless versions of themselves because NY salt kills exhausts and I want this to last at least 5 more years. All of them appear very similar in construction and methodology. All of them use the factory "norma" clamp to secure the lovely ball and socket connection to the cat. I looked at Magnaflow but I learned that the Magnaflow kit retains some version of the V4 "flapper valve". I have my AFM tuned out and don't want that valve in my pipe, so Magnaflow is out. As far as I know, none of the systems I posted above retain any verison of the flapper.
The Corsa is like double the price of the other three. Is it really worth it? I know many here have used Corsa.
Just looking for input and opinions and if anyone here has personally used any of these kits, I'd love to hear from you!
Thanks.
Thanks.
