tRidiot
- Joined
- Dec 21, 2011
- Posts
- 376
- Reaction score
- 290
Ok, so I was pretty confused for a bit when researching this fuel pump. Using the Esky or Yukon I can look at the 6.0, but it shows a different fuel pump - with 3 fuel line/hose connections, a flat 4-prong connector and flat 3-prong connector... Delphi part FG0808. This is the same pump as the gas (non Flex) version of the 5.3L.
But on the 5.3, the Flex fuel option has 2 fuel line/hose connections, a square 4-prong connector and flat 3-prong connector... Delphi part FG0810.
These pumps show similar, though not identical flow rates and PSI.
So my assumption (dangerous, I know) is I should get the Flex fuel because I am using the fuel rails and such off my 5.3L for the new 6.0L, and of course because the connections will match up at the tank. Again, the intake and fuel setup from the Flex fuel 5.3L will work fine with the 6.0L even though it wasn't offered with a Flex fuel option? I'm just double-checking this, as that's what I've been told earlier in this thread or the other one I made.
I think it's pretty clear, but I'm putting this here for the 5.3L and 6.0L also for future generations that may search for this topic.
