I've obtained my ACDelco TDS subscription, and my serial port to usb port adapter. I need some guidance on how to proceed.
From
@swathdiver :
1. At the truck, go into SPS and it will download the truck's specifications into the Tech-2. (
Completed)
2. Go to the house computer and logon on to TDS and then connect the Tech-2 when it tells you to which then gives you access to all the modules. (
Logged onto TDS, but it does not tell me to connect the Tech 2, so I am now at a standstill on what to do next. So, I went ahead and connected the Tech 2, but nothing seems to be happening.)
3. Select the modules to be programmed and then they will download to the Tech-2 (
where and how?).
4. Disconnect from the PC, go back to the truck and into SPS and it will update the modules.
I honestly do not know specifically how I should be navigating this TDS site.
After logging in, I see options for Subscriptions, Keycodes, My Orders, Store, and Resources, and it appears to default to Subscriptions. I see that I have an active subscription for Vehicle Programming Software. If I select View, I get a pop-up Window called VIN Subscriptions, and I select Add VIN. A new Window opens, and it tells me that I have unread news, and I select OK. A new Window opens with the tabs, Home, SPS, Security, SPS Info, Utility. It defaults to the Home tab, and listed below it are 3 options Service Programming System, Security Access, Calibration Information.
I select Service Programming System, and the Window moves to the SPS tab, and I select Start SPS, and it prompts me to download a file, and I download the file to my PC. I don't know what I am supposed to do with this file.
I select the SPS Info tab, and I enter my VIN number and select Get CAL ID. A Window opens with a drop down menu with the different controllers for the truck. In the drop down menu, I select BCM Body Control Module - Programming, and I select Next.
I get another drop down menu, presumably for the BCM, and it contains selectable options Operating System, System, Charging/Energy Storage, Interior/Exterior Lighting, Wiper Control, Locking (in red font), Theft Deterrent Alarm, HVAC Control, Powertrain Control, Chassis Control, Driveline. It appears that I can select only one at a time, but I do not know what to select for my specific B1000 DTC. So, I select Operating System, and select Next, and nothing happens. I repeat this for all of the listed options in the drop down menu, and nothing happens for any of them.
I'm lost.
