HELP! Really odd problems...
T
Indiana
so where should i have put the grease?? and also, the injector problem persisted on the passenger side, so i swapped the clips, problem moved to the driver side. how do i tell if its a bad clip or something else??
SunlitComet
OBS Jedi-Do Good
unknown at this time.
it would probably be very wise to do a continuity test of feed and ground switching wires on injectors to eliminate bad wiring as the cause. if the injectors wiring is good then the ecm must be the issue.
T
Indiana
please explain that procedure in more detail as the ECM is still under warranty and id like to replace it before that expires
SunlitComet
OBS Jedi-Do Good
well make sure your connectors are clean. ensure the red and white wires on connectors are receiving the same voltage when key is on. trace the other two back to blue connector i think on the ecm. and continuity them individually. might even measure the voltage of them at ecm with key on using the same body ground for neg probe of multimeter to see what voltage makes it thru the injectors. if measurements are the same roughly and indicate no broken or loose wires(wiggle the engine harness a bit to make sure)the ecm connectors or ecm has to be cuasing the issues.
T
Indiana
so measure at the electrical connectors on top of the injectors, then again at the electrical connector on the ecm? and if those are the same, all my connections in between are good (thank god) and its gotta be the ecm? correct?
SunlitComet
OBS Jedi-Do Good
something like that.
---------- Post added at 10:48 PM ---------- Previous post was at 10:40 PM ----------
sorry red connector. a16 and a9 cavities.
Polomatt
