Help!
chevykid91
Hi guys, I have really appreciated all the help from you before. Here's one thats got me stumped. I have a 94 gmc yukon 5 speed. I had a few problems with it previously and like no starting when hot. I have replacedthe coolant temp sensor, distributor( includes pickup, module, cap and rotor) brand new. coil. I started have a no spark problem so I replaced the distributor under warranty. now its an intermittant no start because of no injector pulse. it starts when cold, and when it feels like it when its hot. if it does not start, one of the injectors will give a quick spurt of fuel as soon as you hit the key and also as soon as you release the key from cranking it. I'm going to verifiy spark tomorow, but if it does have spark and fires up with starting fluid what should I look at next? and if I don't have spark and no fuel what are the possibilities. I really love driving it and don't want to give up at this point. I've already put a ton of man hours into this rig and am stumped. If anyone has any suggestions I thank you ahead of time.:emotions122:
C
chevykid91
doesn't the new distributer have that. I'll do it anyways just to be sure. will that cause it to overheat and give a no start?
C
chevykid91
its has grease under the module, maybe if I caked on more? heyif worse comes to worse, I'll convert it to a carb, lol
C
chevykid91
its pretty much non exsistant when its hot. When its hot sometimes the injectors work sometimes they dont. one of the inj. will spurt when you first touch the key and also when you release the key. and sometimes they will work fine. It always happens when the engine is hot, but also occasionaly when its humid and hot outside. basically somethings killing the injectors. I'm really just out of options at this point. would a carb convert be dificult?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
the injectors are + power fed and negatively switched on/off by the ecm . check to make sure the red and white wires on injectors are getting proper power when ignition switch is on.
C
chevykid91
Will do, if they do not have proper voltage. Then i'm assuming its either wiring or ecu.
retorq
Kingman AZ
Do you get fuel pressure when it's in the no start stage?? I had my truck vapor lock on me once, wouldn't start until it was cooled down. I have a gauge on mine and was able to verify 0 pressure.
GregD99
