SunlitComet
OBS Jedi-Do Good
chevykid91 said:Will do, if they do not have proper voltage. Then i'm assuming its either wiring or ecu.
Assuming you are talking positive side of voltage, that would be from bat to fuses to ignition switch to more fuses to the injectors. From the injectors to ecm you would be looking for the negative side of voltage. Ground basically. When the key is on and the ground side of injectors have a decent low resistance ground they will activate open. If there is a break there the ecu may not be able to command them open properly.
