HHO kits
zach2011
Platinum Member
What do you think of them? For those who don't know, it is a kit that creates a hydrogen gas for use in the engine, which therefore saves a lot of gasoline and improves MPG.
Basically, you place a quart-sized container of distilled water and sodium bicarbonate under the hood. 12 volts of electricity powers the system (from your battery), a vacuum is created, and HHO gas is generated and pushed into the carburetor.
I would put mine in the spare battery tray, but do you think it is worth the couple hundred $$ to install? What are your thoughts?
Thanks
tx07tahoe
Houston,Tx
My uncle has one in his Saturn. He doesnt really conplain about it so I guess it works.
kickitandholdit
GA
my good buddy had one and he found out over time they have been tearing up motors and he said it didnt make a big enough difference to risk it. he told me it was ********* and he threw it away. and his dad put one on a truck and it didnt make a difference either, he actually forgot he had it on there. all those easy "gas saver" type things are just ******** in a bottle on sail.
its kinda like the same "BS" type stuff in the auto parts stores that if your motor is smoking and knocking and about to blow up just add this to your oil change HAHAHAHA
its all so convincing but none of it ever works, they make money off of trying to make you believe what you want to hear.
mhessick
