I'm in the planning stages of potentially getting rid of the crappy Bose. My two main issues are money and space. This thread isn't necessarily about component selection so space is my issue. I searched but I'm not sure if I'm using the right words to find what I was looking for but only found two threads with no pictures.
Since newer amplifiers have gotten so small, I'm pretty sure a 5 channel amplifier can fit in place of the stock Bose amp "under" the console. My main concern with this is there enough airflow/room so the aftermarket amplifier won't overheat. Is there any other place to hide the amplifier that wouldn't involve drilling holes in expensive and/or discontinued interior trim panels?
Also, where does everyone run the power wires inside? Where the big wiring harness goes through on the driver side seems like the easiest place but then the wire has to cross the engine compartment to get there from the battery and then has to go by the parking brake ratchet. What about the ground? I know lots of install places ground to the body but that doesn't seem like that would be the greatest ground unless the ground strap from the engine to the firewall was upgraded. The last two vehicles I've done system's in have had the battery in the trunk which made things so much easier!
