DaveLaz- Could you post a pic of that Torsion bar fit? And a few more questions since it seemed like everyone focused on shocks, which aint it if it drives as poorly as you describe.
Were the Control arms torqued while at ride height? Do you have a panhard bar? Have you tried with it disconnected? If your Sway bar links are loose they will rattle or may clunk a little. Any Gaps at Control arm mounts? As in room to move. Mounts tight front and rear?(8) Have you tried a pry bar test to see whats moving?
Report your findings, I'll watch.
Yup I’ll post a pic below. Great questions!
-Everything was torqued down when set down on the floor. I did this multiple times including even driving slowly around the block and pulling back in and torquing everything.
-I do not have a pan hard bar. That was next in the plans after I finishing lowering it.
-I completely removed the sway bar end links to rule out that being an issue with noises/ride.
-I actually did notice some room on the LCA mounts yesterday so hmmmm
-I’ve wiggled and pried all over the place which is how I found out I needed torsion crossmember mounts. Got those installed and it did nothing
-I ordered new ball joints for the LCAs and I’ll be pressing them into my original control arms when they come in. Ill then install the OEM ones and re-index the torsion bars. Then I’ll grease the sway bar D mounts and reattach the end links
-Any other suggestions to check on or adjust when I go back under?
