Horrible sway
08HoeCD
Welcome to the weird world of suspension dynamics.
Glad that you figured it out and can fix it easily.
Rebelmyers
My truck random darts to left or right. I think mine maybe the steering stabilizer
Rebelmyers
I'm wonder if isn't the steering stabilizer sensor
Eric70
Replace your rear control arms. I just replaced mine this weeknd. Huge difference.
I got the control arms from rockauto, but the lateral rod had to be purchased at my local dealership.
Took less than 2 hours for all 5 pieces.
Eric70
If the rear axle doesn't perpendicular to the frame and front wheels, it will change the direction of motion. That will cause the driver to compensate by turning the steering wheel.
Any wear, slop, or looseness in the suspension will have an impact on drivability.
If a person can move any mount or connection point by hand, or a short pry bar, imagine what about 6,000 lbs does in a curve or corner at speed.
Rebelmyers
Will check that out next week. Thanks
Chip18
Dayton NV
Both
Well that's certainly not helpful! Nonetheless it would not hurt to check all the Caliper slider bolts to make sure they are properly lubed.:
Unfortunately .. it's not darting hard to one side under braking but checking all the slider bolts ... can't hurt. :)
Torrance1978
