drakon543
- Joined
- Feb 15, 2016
- Posts
- 2,473
- Reaction score
- 1,714
To find out what gear ratio your truck came with, check the RPO sticker in the glovebox and look for the following codes:
GT4 Rear axle, 3.73 ratio
GT5 Rear axle, 4.10 ratio
GU5 Rear axle, 3.23 ratio
GU6 Rear axle, 3.42 ratio
If you don't have enough gear, one thing you'll notice is the transmission dropping out of OD on the highway on any sort or grade or headwind. When that happens the back and forth is hurting your mileage.
My truck came with the horrible 3.23 gear. With stock tires it was bad. On our family vacation loaded down with gear it was dropping out of OD all the time. With 34" tires it was even worse. It was a pig and always seemed to be struggling in the wrong gear. I put in 4.10s, and the truck now does everything effortlessly without messing with the gear lever. I might should have gone with 4.30s, but so far 4.10s seem just about right for me.
If you have 4.10s or even 3.73s, it might not be worth the money to swap if the truck seems like it is running ok.
You aren't going to get much better mileage than that. Gears, fans, and tune, plus basic maintenance stuff will help though.
My slightly lowered stock denali on stock wheels averages like 13mpg...
i did some reading when i first got my stock truck. But people always post mods claiming amazing advantages, but never back it up with proof. It would be nice to do a test with each mod. and do dyno test before and after.
At this point any increase is worth it. I usually try to go on like 1 road trip a month and some of these trips are 1 day trips where I'll drive anywhere from 100 to 500 miles in 1 day. And if I go on a full weekend trip I'll drive anywhere from 300 to 1600 miles in like 3 days. So whenever I'm taking these longer drives, if I can save a good bit of money on gas then it's completely worth any increase to me.
