How do I fix this?!
19Yukon97
Texas
Sunlitcomet- I think the rear of the headliner is held on by clips. atleast mine was like that when i was putting my new speakers and running wires up there. the front its held on bythe grab handle bolts and the roof console if you have one.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Actually I now recall that there were screws as well. I forgot the sun visors were screwed thru the head liners plus something else. Oh well.
T-Bagg
T-Bagg
The Esca-Hoe driver.
Doesn't Matter
I pulled the rear of the headliner(held up by bolts in the grab handles and the trim in the rear) and there is a metal plate that covers those receptacles from the inside. I was going to run bolts all the way through and put fender washers and nuts on the inside, securing the washer and nut to the roof with J-B Weld if I ever want to pull the rack off again. Those plates cancelled that.
So, instead, I'm going to put the stock receptacles/nuts back into the roof. With a little J-B Weld around the rim and tap the metal back into place to hold it. I'm also putting a lite coat of J-B Weld around the holes to reinforce the cracks there.
I'm no longer going to carry the spare up there. Because I think it was the weight of that on top of the Hi-Lift that pulled the rack off in the jump. As I'm sure that exceeded the hundred pound weight limit up there.
T-Bagg
T-Bagg
Doesn't Matter
Finally fixed the roof rack. My JB Weld solution did not work. it failed almost immediately. How I fixed it.
Removed the headliner to access the underside of the roof.
The headliner was held in by, moving from back to front: Plastic trim, Bolts through the hooks and grab handles, back seat belt bolts(I couldn't get any tools on these, the window would have to come out so I cut the trim and slid it around the bolt. barely noticeable), trim that runs up the B-pillar(clipped in), front seat belt bolts(torx bits), bolts through the grab handles above the passenger door and A-pillar, trim over the doors(handles hold these on plus clips), screws holding the sun visors up, the over head console(fastened by one screw at the front) and the cabin lights(pop the light cover off and two screws underneath).
The roof rack receptacles are hidden behind some steel.
Here in the back,
And here in the front,
The old receptacles were broken free so I just pulled those out the top. To be replaced with these,
Different lengths of 1/4 in socket head bolts, fender washers and nylon locking nuts.
To gain access to thread the washer and nut onto the bolt. Holes had to be drilled through the steel.
In the back, the hole on the left(back) was already there but had to be filed open to allow a 7/16 socket. the other had to be drilled. I stuck the bolts through from the roof. Placed the washers over the new holes with some serious finger ******* and using long skinny tools(a file) to push them around.
I put the 7/16 nut into the socket and on the end of an extension. I pushed the socket through the hole and balanced the washer on it as I pressed them onto the bolt threads. This required patience.
The front, the hole on the right(front) was there, unfortunately those were the only receptacles not to break. The other hole had to be drilled and filled open to allow a socket. The front was significantly easier than the back as I could use my skinny ass fingers to put the washers on the bolts and then the socket and extension to install the nut.
Tightened everything down and then re-installed the headliner.
Hope this helps anyone else who breaks their rack off or just wants to strengthen up their rack a little.
jd08
Jackson, WI
Looks good but did you seal up around the bolts at all so no water leaks in?
96ProCompTahoe
IN
that looks like it was a pain in the ass! rethinking the roof rack i had planned for the 'hoe as im starting to think it won't be solid enough for the $ and trouble.
Chadly14
