How is this possible?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
you can contact the company fastlane, they quoted a guy $1,800 to do it, and the DIC won't work...
http://www.gmfullsize.com/forum/showthread.php?t=216874
1. This is NOT a direct plug-in swap cluster.
2. You have chop into the cluster wire harness to make work.
3. You have to modify the bezel around cluster to make look right, it does not fit.
4. It took them 2+ weeks to make work, but they do know what to do now.
5. Everything works, but the "Info" window will not display anything.
Give him a call if you have you heart set on it.
713-600-8600 ask for Nick
Modded
That Guy
The whole Esky cluster thing has been discussed in the past. It is possible, but a very pricey/extensive install.
Don't even bother Regency. I doubt you will want to fork over the $$$$ needed for that mod.
It will run at least $800 for it to be done right because the cluster alone is around $350. Not even close to worth it.
Regency
Regency
I kinda want it not desired though just wondering how this dude did it maybe if I find a brief case or win the lotto haha
akram
