How to do an oil change
tedward
I'm tired of sending my tahoe to the oil change place and they always call back to tell me something else needs to be fixed, or replaced. I have never changed the oil in my 99 2dr tahoe. I searched for this help, but couldnt find anything. If you guys could give me some advice on how and what I need to change my oil, I would greatly appreicate it! And anything else I need to look out for when doing the oil change.
Thanks
Gzes
the drifting 2dr
Wichita tx
its easy just remove oil from pan take out filter and oil the filter then put it in and put new oil
Administrator
Remove plug from oil pan (15 mm socket), remove filter (filter wrench), let oil drain, put plug back in, put in new oil filter, put in appropriate amount of oil, check oil level and roll :waytogo:
LI99HOE
Top Notch Tech.
N.Y.
+1
No need to buy a manual.
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
There's a thread on here that's quite helpful o. Hot to change the oil... Not sure who made I'll look for you it goes in great detail
LI99HOE
Top Notch Tech.
N.Y.
Thanks guys! How many quarts of oil should I buy?
Soooo many discussions on this.
Buy 6, put in 5 and check it.
If ya need more....add.
If it's good, you got a spare quart.
Administrator
If it's 4x4 it's most likely 6 qts that is needed
T
tedward
What brand of oil is eveybody using? My tahoe has just a lil over 200k miles
MRBJU52
