How to do the 4 or 6 high mod on an 03-06 full size truck for $3.00
1highbaldguy
So Cal
sweet. im going to have to try this.
does anyone know if its possible to do a 6 low mod? if so, how does the wiring go for the diodes?
undercover_skank
LongBeach
easiest and cheapest mod ever! did it today and it worked just fine. got the diodes from radio shack for like 1.50. thanks!
firehill
Texas
ok, sorry but maybe i missed something. Why can't the 4 high or 6 high with the diodes be done on a '02? Something different in the fuse panel?
DenaliAK
Colder than you
Alaska
I'm not sure it COULDN'T be done, just that it's even easier to ground the yellow wire. Saves you a buck or two on diodes, too.
Mine's an '03, so I don't know for sure, though.
firehill
Texas
ok, just looked at my '02 and it doesn't seem to have a seperate relay in the fuse box for the low and high been. the only one i see was labeled "HDLP" so might have to go the cheap route of grounding the yellow wire.
TnTahoe
TN
I know this is late but for the guy worried about the inspection, you could easily just take the diodes out before inspection and then just put them back afterwards
vatahoelt
NoVa
yeah, i just say f'it and put them in. i don't get inspection for another 7 months or so.
kickitandholdit
GA
i have don that under the dash but i really won those day time drining lights in the middle on too pleas let me know if it can be done thanks
Alsherooqi
