How to do the 4 or 6 high mod on an 03-06 full size truck for $3.00
chip
Tampa
Yeah, that's what it is then! I think the position of the actual relay may be inconsequential, because all of mine are right side up. So I think the important points are where the diodes should sit in the sockets, as opposed to which pins to jump.
BillBlatt18
Latham, NY
i tried doing this and they both come on for the low beams and only the highs come on for the high beams. Can someone help?
---------- Post added at 07:22 PM ---------- Previous post was at 07:03 PM ----------
nvrmnd i got it, the band was facing the wrong way
oakrdrs187
Coachella,CA
If anyone is having a problem with the fogs flash when the high beam is turned off i have a solution. I have HID Fogs and Lows and after i did this mod I noticed that when my high beams were brought from ON to OFF, the Fog lights cut out and come back due to a Small lag in current from the relay quickly switching around, so for me and anyone with and HID setup that is NO Good! SO What I did is get the diode that goes from the HI relay to fog and moved it from LOW relay to fog and the problem was solved and you have the option of driving with just fogs again. So to put it simple. follow the 4HI mod as mentioned on the thread, and for the fog, put the diode in the same place as before on the fog light side and in to your low beam relay where the high beam diode goes in, so what you will have is kind like wiring in series, diode from HI to LO and from LO to FOG.
It helped me eliminate MY fog light "flicker"
sparg93
Expedition Tahoe
NJ
if you have a 99-02 chevy you can do the high 4 for free by grounding the yellow wire on the driver side headlight.....
Has anyone else tried this for their Tahoe? (mine is a '99)
TailHook
Tattooed Millionaire
Arizona
The diode route will work, but...
Pros:
Cheap
Fast
Easy
Cons:
Fuseblock terminal stress
Intermittent connections due to "friction" fit
Diode failure
Heat (i.e. fire risk)
Since the "project triangle" concept states you can't have all three ("cheap", "fast" and "good") and being the perfectionist that I am, I went the relay route to isolate the two circuits from one another and increase safety/reliability. Obviously there is a cost/effort to doing it this way, but I have peace of mind that it's done right (according to my standards, anyway!)
chip
Tampa
Pros:
Cheap
Fast
Easy
Cons:
Diode failure
This is exactly what I was looking for! Thank you Sir! Very much appreciated!!
chacho44
MOTORCITY
Pros:
Cheap
Fast
Easy
Cons:
Diode failure
Sorry Im dumb, I dont understand
Jasrancore
