How to slightly lower the front?
GarrettMoore
When I deleted my Magneride for standard struts, it raised the front end about an inch.
Is there any way to bring it back down without swapping the spring?
The installer said there was a bolt or bracket that could be flipped to do so. Is that true?
When you replaced your Z95 Magneride system, did you replace the rear springs with non-Z95 specification springs? Without the spring replacement, your rear will sag a bit, making the front of the truck appear to be too high in relation to the rear.
jvanwanz
