HVAC fan speed question
billowred
Perfect thanks! Cuz when I pulled mine the plastic broke too. I'll order one right now.
bowtiefreak
bowtiefreak
No Quarter
Near Philly
did you check the out put of the switch to make sure it isn't the resistor? If the resistor is bad let me know, I have an extra
billowred
No, I found the controller for $80 on amazon so I'll try that first. I'll let you know.I appreciate it.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you know even with broken tabs it can still fit and look good. use the folding of the wiring as spring tension to push the controller out. then use the dash bezel to hold it in. with only a fan switch that needed replacement there was no reason for me to buy a whole new unit because of broken tabs. Absolutely nothing wrong doing that and it still looks great.
billowred
My tabs have been broken for about a year. Once it's put together you can't tell. I bought the new unit because the 3rd speed stopped working, I checked the resistor and it's fine.
Tjf2222
