I installed E-fans on my 2001
YukonXL04
The Riverboat
Arlington, TX
Ls1fans.net has the pulley.
The factory harness will attach to the under hood fuse panel. Pretty sure you have to remove the fuse panel cover so you can access the power stud
I used ls1fans harness and overdrive alternator pulley with good results.
alacran
Can someone put this in dummy terms. My head hurts (well not really lol). Yes I have used google.
I have a 01 tahoe and have the oem fans and harness. And i can't understand which wires and where they go to into the pcm? Thank you in advance
kses123
kses123
Raleigh, NC
See the little black connector hanging by itself? It has two tiny wires in it, one blue and one green. Those are the two that go into the PCM.
bottomline2000
Dallas, TX
Not on an 01. Blue wire to pcm, green wire will have to go to ac trigger. Have to tap the wire running from the compressor but u can access it like @ScottyBoy did. Makes for a clean install. Also have to wire in a relay for the ac trigger.
Sent from my SAMSUNG-SM-T377A using Tapatalk
alacran
Ok thanks i just got the plug and pins from the junk yard. I need a tune after this correct
Thundergunexpress
