I need help please on abs- **SOLVED**
I think its fixed. What i think happened was, the 2 wires coming out of vss were showing the wire as if someone had messed with it at some point, i think moisture was getting in the plug and grounding it out. So initially i checked the continuity and it was good so i used liquid electric tape to seal it up, and i installed the new vss, which didnt work. So after View attachment 304873much head scratching and test i noticed the new vss had this plug in shape, which did not match my factory plug in. So i installed the old vss, pinched the female pins in a little and installed it with dielectric grease, and now it works.. So my initial find and fix probably worked but the plug in didnt match.. i also changed the ground wire from floor to frame below the drivers side floor, it was almost completely severed on one end, only 5 or 6 strands holding it on. Also i think the abs module probably had the bad relay as described before. Im not 100% sure which thing fixed it.. Just letting yall know, i really appreciate all the help..
Well at least it looks like it’s fixed. A ground wire issue is every bit as important as a power or signal wire issue.
rockola1971
Indiana (formerly IL)
Absolutely. The ground wire has the same amount of current flowing in it as the positive wire does. You cant have power consumed in a load without the ground wire making a good connection to ground/negative terminal of battery.
BentleyArnage
Washington
Look for the VSS on tcase or trans. Losing Speedo and in limp home a bad indicator. I'm not sure what your truck has equipped wise. Some are internal. Know a transmission guy?
On the newer trans, the input speed sensor is in the trans. The output is in the tailshaft or the T-case. If you have a 4L80E, there's an output sensor in the case as well.
twitchtucker
