I seem to have a coolant leak.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Drive it and check the coolant level. Drive it and check the coolant level. Drive it and check the coolant level........Repeat!
TURNz
TURNz
that's been my plan so far. Though i get so nervous about opening the cap before its cooled off. I saw a guy get sprayed with coolant before. So i always wait until it's down to 140f or so. Which can take a while.
I'm off work today, and i need the tahoe all day tomorrow.
So hopefully I'll get a few drive and check cycles in.
Is there a way to tell if the stat is opening or not?
Sent from my SM-G935V using Tapatalk
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
If your gauge looks good and you are getting heat inside, the stat is doing it's job. Plus, if you had a laser thermometer you could point and click, so to speak. Always let the coolant cool down and that helps air pockets escape.
mattt
I'm going to be replacing a water pump soon here. I may change to a different coolant instead of Dexcool. Does the 5.3 block have drain plugs like previous generation SBC and BBC's? I'd like to drain the block during the swap, even if I don't change coolant type. 266k miles could have built up crap in the block water jackets. Thanks in advance.
certa
