I suspect BCM... thoughts?
I took it out of the truck and brought it in. They had a little box with what looked like jumper cable clamps on it. Of course I had recently topped it off when I took it in so the voltage was fine, but I thought it would be able to test for other stuff (amps, etc). Maybe not. I'm gonna let it draw down again (it's at 12.3V again right now) and take it in again.
next time it won't start pop the hood and put your meter on it, then have a helper turn the key to start while you watch the voltage, the voltage should be 10.5v or more while the key is in the start position
T
TrybalRage
12.3 v is at 60% state of charge. That battery is junk. Its self discharging.
I agree. It was bought new in November 2021 so I'd like to get it replaced under warranty. Just need Autozone to agree as well.
Anytime they test it they should give you a printout of the results. Should tell how many amps it can deliver.
petethepug
Michael
SoCal
The slow charge is the best way to charge a standard lead acid battery. Step 2 is taking to a shop / store that can immediately preform a load test. If the battery fails that test you’ve got a bad cell. This means you can charge the battery to 12V + but you don’t have the cold crank amps to start the truck.
Geotrash
Dave
Richmond, VA
I had a bad battery in our Infiniti that was 9 months old. I swore I had a parasitic drain but like you it always tested low draw when I’d check. Every 4-5 days of sitting it would need a jump until it got to where it wouldn’t start after sitting overnight. Took the battery back to advanced auto where I bought it and they took it out and tested it in the store. Couldn’t find anything wrong so they wouldn’t warranty it. Told me I had a problem with the car’s charging system. So I went to Autozone and bought the cheapest conventional battery they had that fit properly, for $99 on sale. No more problems even after sitting for a couple of weeks.
My money is on the battery too.
Also, I will now only buy the cheapest conventional battery I can find.
T
TrybalRage
Well, ladies and gents, the saga continues.
I've been driving the suburban every day, so the battery should be maintaining a state of charge. But it seems low again, and I went to start it this afternoon and got all the same symptoms.
No gear position
No fuel gauge
Service 4wd
Service ABS
And so on.
I tried to plug in the Tech2, but it would just show 'no communication' for all modules until I disconnected/reconnected the battery.
Afterwards, I was able to do a scan and pulled 23 (!) codes. I took snapshots of them all at this imgur link:
The first 2 were errors I got BEFORE resetting the system.
The last one is a battery state snapshot.
There are a couple that stand out to me:
#13 and #14. When I plug that code into alldatadiy, there's an interesting article about fleet vehicles with add-ons causing issues including battery drain... hmmm. My truck was "corporate owned" according to carfax, and there are holes and such in the headlights where flashers used to be.
Known Symptoms (not specific to any one device)
  • The radio may not shut off after shutting down vehicle.
  • Bus or LAN traffic may stay active leading to a discharged vehicle battery.
  • Problems reprogramming modules either because of interference or the device will not allow the bus to power down.
  • ONSTAR® may lose the ability to provide diagnostic data.
  • Various engine and transmission performance issues with SES light set.
  • Intermittent driveability issues.
  • Reduced power message and codes.
  • Stabilitrak® message and codes.
  • C0561 stored in the EBCM leading to a traction control issue.
  • No high speed LAN communication along with various communication U-codes.
  • Transmission may not shift for one key cycle (TCM in default mode).
  • Erratic gauge readings or flickering displays.
  • SES, MIL or CEL light set and numerous DTC communication codes such as U0100, U0101, U186B and U1862.
  • Diesel power-up devices causing no power in 4WD low range.
  • Erratic electric power steering boost potentially associated with codes U2109, U2107, U2100, B1325, C0000.
  • Battery run down
  • Service Tire Pressure Monitoring (TPM) system light illuminated.
    – Cannot relearn TPM
However I cannot see anything that might relate to this under the dash...
#18 current no communication with TCM, but the other glaring issues at this point are gone due to the 'reset'.
The rest I am attributing to what I am terming "GSF" - General System Freakout
intheburbs
SE MI
Have you tested the alternator beside just checking the voltage output with a multimeter? If it's not properly charging the battery, that would explain just about everything.
CoyotesRUS
