Matthew Jeschke
I'm moving this from another thread. My fuel mileage has been suffering for quite some time and I think this is contributing factor. I honestly, only really know basics of troubleshooting fuel pressure. Maybe this is operating correctly, or maybe not?
Vacuum Check: I did a sanity check, revved the engine and fuel remained low by 20%. So I suspect it's fuel.
Rail Pressure:
Key on Ignition off: 50 PSI (I think should be ~58PSI ?)
Engine Running: 50 PSI when revved the pressure drops quickly down to nearly ~45 PSI
Pressure bleads off slowly when ignition is shut off. I'm not sure if it should hold 50PSI in there? It slowly bleeds down but engine starts like a champ... check ball bad in pump?
FEW NOTES/ BACKSTORY: Truck is a custom built LQ9 w/ Flex Fuel injectors. Note I went from around 24lbs / hr to ~32 lbs per hour... although, I don't think I had the fuel demand so flow should be similar to stock injectors maybe if anything a touch higher? I swapped the Flex Fuel injectors in because my 24# stock LQ9 injectors were leaking. Long story short, I think fuel demand / load on pump is VERY similar to the stock injectors (if anything I shortened the injector duty cycle). I tuned the VE table and am running in speed density mode. I went to log some more data a couple months later and noticed instead of my LTFT being well within 5% as tuned they are now around 20%.
New OEM pump - as spec'ed for LQ9 (not flex fuel, swapping whole system to flex fuel was a LOT of work / didn't have all the parts).
New pressure regulator on order - note when I unplugged the regulator w/ engine running pressure shot to 58 PSI.
Got a new filter to install
VIDEO OF SYMPTOMS LINKED HERE
Rail Pressure:
