Inner door handles broken...
commercialcobb
Whats the trick to getting the door panel off and what do I expect to find broken? The driver door and rear passenger door handles are just flopping around. The driver door got looser and looser where I was shouldering the door to get it to open before it broke. I know this is common just wanted to know...
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Door Trim Panel Replacement
82160945
Front Door Trim Panel
82160946
Front Door Trim Panel Courtesy Lamp
Tool Required : J 38778 Trim Panel Remover.
Remove or Disconnect
  1. Door handle bezel. Refer to Inside Handle Bezel.
  2. Window regulator handle (if equipped). Refer to Window Regulator Handle.
  3. Power accessory mounting panel wiring connector (if equipped with power accessories). Refer to Door Power Accessory Mounting Panel.
  4. Trim Panel Upper Extension. Refer to Trim Panel Upper Extension.
  5. Trim panel armrest screws. Carefully pry off trim panel armrest screw cover with a flat blade tool to access screw.
  6. Trim panel from the door. Carefully pry the retainers from their seats using J 38778. Disconnect courtesy light connector (if equipped).
  7. Courtesy Lamp lens or reflector.
  8. Retainers from trim panel. Pull retainers from slot.
Install or Connect
  1. Retainers to trim panel. Push retainer from slot.
  2. Courtesy lamp lens or reflector.
  3. Trim panel to the door. Align retainers with holes in door. Carefully apply pressure to seat retainers.
  4. Window regulator handle (if equipped). Refer to Window Regulator Handle.
  5. Power accessory switch mounting panel (if equipped with power accessories).
  6. Trim panel arm rest screw. Tighten : Trim panel armrest screw to 1.9 Nm (17 lbs. in.) . Insert screw cover.
  7. Trim Panel Upper Extension.
  8. Door handle bezel. Refer to Inside Handle Bezel.
cobbcfi
Charleston, SC
sunlitcomet, you do rock.. By the way, I have thrown prolly 1,000 plus bags into that CRJ-700 or 900 for Piedmont in Charlotte Douglas Intl CLT.. Love ur profile picture, I'll give this a try and let you know what happens.. I was Ramp Supervisor for 3 years in CLT and CHS.
---------- Post added at 08:32 PM ---------- Previous post was at 08:31 PM ----------
Why do your pictures keep changing?? Went from engine, to fuel pump, to door trim and now back to fuel pump replacement?? lol
---------- Post added at 08:33 PM ---------- Previous post was at 08:32 PM ----------
now its showing how to polish the cylinders... hahaha
qukon 95
mine broke today and i will put my old door latch back on too. it got worst
to open door so i ordered 2 chrome handles to put on.
Faro
