Installing a Dash cam.
bigrhino
l.e.s manhattan,nyc
I have a 2011 Tahoe and would like to install a dash cam using power from the interior fuse box. What's a good fuse to hook up to for on power, off power?
if it is usb get a 12v to usb adapter there a lot of them on ebay, you can run the cable from the drivers floor kickbox up the pillar and under the edge of the headliner, wire it up to accessory power.
madmanjustice
I have a 3rd Gen Rexing V1P dash cam and got their hard wire kit. I opened my overhead console (i have a PPV) and there was an unused harness that had a switched power wire in it. I tapped into that wire and got power to the dashcam with the hardwire kit. and there is plenty of space for the extra wire in the kit and there is also a spot where you can put a self tapping screw for a solid ground.
stking
