Installing a steering damper this week.
Red_Raider
Derby, Kansas
Is that the correct part number for the Bilstein.? When I searched on Amazon it says that it doesn't fit my 2002 2wd Tahoe.
Mr. 960
all done! Skid plate goes over bracket. However, I had to turn the damper around, and have the body on the passenger side. Reason being, is that I have the Cognito steering brace and the pitman arm bracket would hit the damper cylinder. I called Rough country and the dude said it was okay to reverse the damper. He did not sound to convincing..... anyone have a different opinion?
Mudfrog
Care to share some pics? My KYB setup will be here in a few days. I'm trying to do it at the same time that I do my level and larger tires. As for the direction of the stabilizer, I don't see why it would make a difference. It should give equal resistance in both directions.
Mr. 960
I'd love to share picts..... but I've never lernt how. I've been a member at GMFS forum since 05 and still don't know how :( What do you need photo bucket? Tried a long time ago and got frustrated.
Mudfrog
Photobucket, Flickr, etc. No biggie if you can't, I just like to look at examples before I dive into stuff.
jough
Arkansas
Well, I ordered the KYB SS15326 today from KYB Outlet. I easily found a coupon code as well. Total cost shipped was about $47. It looks like it will work fine with a 2-2.5" leveling (torsion key) lift.
TheAutumnWind
No problem turning it around.
Mudfrog
I just installed mine. While it was fairly self explanatory the instructions were incomplete (KYB Brand). It didn't say anything about using the 9/16" bolt and hardware. It said to use the skid plate bolt on that part of the bracket. I couldn't get the skid plate bolt to start so I drilled it out for the 9/16" bolt.
Mr. 960
I had to drill one large hole, can't remember now maybe 9/16", into the front cross frame. Then you secure it with a large washer and nut. This gives it the main strength. The skid plate bolt just keeps it from sliding around on the larger bolt.
joakleyTYF
