Installing full set of Shocks 2008 LT2
fenix687
One of my friends has a 2008 LT2 that the front strut reservoirs are leaking. he wants to go ahead and install all four.
what is a good set of shocks for him to run?
how difficult are these to install?
is there anything i need to know before getting into it?
does anybody have a downloadable service manual for 2008's?
thanks in advance.
KMeloney
Assuming he has "Autoride" (at least all '09+ LTZs do, and I'll assume the '08s did as well), then I think he may need to replace them with oem autoride shock. Otherwise, without the ability to reattach the sensors that go to each shock (not to mention the air lines to the rear ones), I have read that you'll throw suspension warning lights, etc.
I hope someone else will chime in add pick up where I left off (or correct me altogether).
Zed 71
Pacific NW
Is he stock, lowered, lifted? What are his expectations and budget?
Assuming the existing coils will be reused, a spring compressor is needed. Do you have someone that can show you how to properly use it? You can get serverly injured if it is not used correctly.
F
fenix687
he doesn't really have one. i told him it would probably be about $500 but this website is looking promising for Bilsteins
http://www.shockwarehouse.com/index.cfm?mode=results&selected_model=3854&selected_year=2008
he is stock height and we are wanting to re use the springs. good idea or bad idea?
---------- Post added at 01:08 PM ---------- Previous post was at 01:05 PM ----------
i have a spring compressor. i am not new to modifications. i have an 84 grand wagoneer that i am in process of rebuilding and use to have a 95 4runner that i converted into a overlander. just not that familiar with chevy
Zed 71
Pacific NW
Should be a piece of cake for you then. If the springs are in good shape and he wants to stay stock then resuse them. If he likes the ride as is, then go OEM (Bilsteins are a good option - just read the specs to maintain stock ride).
Hopefully others with street focused rigs will chime in.
