Is changing the 1999 4x4 switch difficult?
ryanideus
nebraska
similar issue
I've had similar problems with my 4x4 switch for years, and its always switched drives fine. Although in the last year I've developed switching problems, in that I can switch from 2wd to 4wd or awd fine, but can't switch back till I turn the truck off and start it back up, then I can switch it back to 2wd.
I have changed the transfer case switch motor, but its still doing it. Any thoughts? will a bad switch cause this? Mechanically everything works fine when it goes from 2wd to 4wd and back (no clunk, jerks, or grinding). So I'm thinking this has to be electronic.
ZeroHour
