Is Moog the only way to go for front end replacement?
HiHoeSilver
Away!
Chicago
I have to ask. Sometimes we just don't have the money to go with the best parts. I just might have to install a piece at a time.
That's an awful lot of taking apart and putting back together. If you can survive on what you have for a bit, maybe just take your time acquiring the parts as you can afford them, and then do the job once.
Kenny D
Crosby, Tx
Any parts come to mind?
One does come to mind, the ball joints for the 91-99 suburban, OEM does not have a grease fitting while most aftermarket parts do. If I am not mistaken, Moog uses better quality hardened steel on theirs than stock also.
jaywoo65
Cabot, AR
AC Delco parts are fine. Amazon has everything you will need. Free shipping also if you're a Prime member.
1992rs
OR
Rare parts make some really high quality stuff. I'm using their tierods, pitman arm, idler arm bracket, along with a moog idler arm and cognito support brackets. Rare parts re-engineers their gm steering parts to fix its faults. My steering feels great without a steering stabilizer but my gearbox is getting worn so I still have some play.
95escahoe
If your doing tie rod ends, pitman arm etc. it's best to do it all at once cause you need to get an alignment for all of that, and plus if you do it piece by piece your alignment might be off and in turn you might damage your new parts if you don't do it all at once
jerryjoe28
That Guy
cabot AR
very true. I have life time alignments on all my rides for this very reason!
MrMiller
Seattle, WA
Sorry in advance for the new guy question but my 04 has 230,000 on it and by the looks of it the front end stuff has not changed. Is there a list of parts that are recommended to be replaced? I would like to have piece of mind.
jaywoo65
Cabot, AR
Well if you want to go crazy and do it all, here's what I'd do (and have done:))
Pitman arm
Idler arm
Idler Link arm
Inner and outer tie rods (both sides)
Upper and lower ball joints (both sides)
Front shocks
Sway bar end links
95escahoe
Pitman arm
Idler arm
Idler Link arm
Front shocks
Sway bar end links
X2 on this check it all out first maybe it's still good, but if you have to do say tie rod ends I'd do everything else while your in there
beka1283
