Is New Engine Break In Procedure Still Necessary?
Silverado4x4
Maryland
I don't believe at all on the letting the engine idle or using remote start is putting more fuel in the engine vs normal driving and getting in the oil. The metered injectors are putting enough fuel in the cylinder needed for combustion and more fuel for higher rpm's so way less fuel at idle that is burned off when combustion is happening. So what is being said here is fuel at idle is washing down the cylinder and draining down to the oil. No way. Only way is if the engine rings are worn and your getting blow by then gas will get in the oil or you have a leaking injector dripping fuel in the cylinder when the motor is not running.
jfoj
@Silverado4x4
Believe what you want. DI engines are a much different animal than previous port injected engines. The higher pressure fuel delivery with DI, especially when the engine is cold will leave liquid drops of fuel in the cylinders especially around the piston rings, liquid fuel does not burn, so it will work its way quicking into the crankcase.
Additional you need to understand the engine coolant temperature and oil warm up behavior of an engine that is just idling from cold start vs driving. See graph below. Cold Start Idle was for 15 minutes, Drive was 17 minutes. Even at 17 minutes of driving the engine oil was only around 175F even though the engine had hit 200F. This was semi rural driving with at best maybe 4 traffic lights and speeds typically between 35-45 MPH. The engine was not even 100% fully warmed up at 17 minutes of driving, usually these engines operate between 203-210F when fully warmed up. Ambient temperatures due influence warm up times, but we are still not out of the Winter temps in many areas. Many owners tend to use the Remote Start features more when the temperatures are colder to warm the cabin and clear the windows, I get it, sometimes you need to to this, but doing this on a regular/daily or multiple times a day basis is not a wise idea.
It also not all about the engine idle time as well, it is about getting the oil, not the engine, up to a high enough temperature to start to "cook" fuel out of the oil. Again, fuel contamination of the oil can be cumulative depending on the outside ambient temperature and how the vehicle is driven. The more short drives, the worse the problem gets.
Pull your dipstic, check the oil level and smell te towel used to wipe the dipstick for fuel. A number of reports about vehicles fresh off the dealer lot have fuel smell in the oil.
blanchard7684
Senior Member
yes I think there is reason to alter driving habits with a new engine, even with modern engines. I would opt to drive it such that the rings will get a good wear pattern. This would be something like stop and go driving and/or varying rpm slightly for a few hundred miles. It doesn't have to be perfect. You won't trash your motor if you don't do this to perfection. The reality is that before you signed the papers 4 other people drove your car and likely floored it repeatedly. lol.
And the DI engine's propensity to put fuel into the oil, I recommend the first oil change quite early as well. I did mine at 1800 miles.
I had a 4runner that I bought off the lot and went on an off roading trip. I literally left with gear from dealer lot. Lots of highway miles and heavy acceleration to pass. High altitudes where the anemic 4runner engine stayed at 4.5K for minutes on end to keep 78 mph. No issues and a total violation of the owners manual break in procedure.
WalleyeMikeIII
Sunny and Snowy Minnesota
The owners manual describes the GM proscribed break in process, which is essentially not much.
Don't use cruise or drive at constant speed/rpm for the first 500 mi
Be gentle on brakes while the pads and rotors seat to each other
Don't tow for firt 500 miles.
Past that I would try to do a few full thermal cycles of getting the engine to full operating temp, then letting it cool all the way back down (which you will probably do anyway in 500 miles).
And maybe somewhere past 350 miles, give it a few higher RPM runs (but not Wide Open Throttle) to around 3500-4000 RPM.
Marky Dissod
2025 Corvette Owners Manual said:
For the first 322 km (200 mi):
• To break in new tires, drive at moderate speeds and avoid hard cornering.
•* New brake linings also need a break-in period. Avoid making hard stops. *This is recommended every time brake linings are replaced.
For the first 800 km (500 mi):
• Avoid full throttle starts and abrupt stops.
• Do not exceed 4000 rpm.
• Avoid driving at any one constant speed, fast or slow, including the use of cruise control.
• Avoid downshifting to brake or slow the vehicle when the engine speed will exceed 4000 rpm.
•* Do not let the engine labor. Never lug the engine. *This rule applies at all times, not just during the break-in period.
For the first 2 414 km (1,500 mi):
• Do not participate in track events, sport driving schools, or similar activities.
• Check engine oil with every refueling, and add if necessary. Oil and fuel consumption may be higher than normal.
Pity that break-in procedures do not include disabling Engine Confusion / DFM.
RET423
No, drive it exactly like you drive whatever else you drive; engine break in is an enduring wives tale
If it's a rebuilt do the first oil change early, other than that let it eat
djnice
GM wrote the owners manual posted above. That's what they recommend. How could they program the computer to randomly change speeds while the owner is driving down the highway.
West 1
Modern pistons rings seat quickly but only when under a load. A new engine will create more heat than a fully broken in engine so watch temperatures closely and never let it overheat.
If you have a long hill to use that is perfect for engine break in, if you are using 50% or more throttle to climb the hill the combustion pressure will help the rings seat in perfectly.
When started on an engine dyne modern rings will seat by the end of the first dyno pull. A dyno pull lasts maybe 30 seconds start to finish but those are done under full throttle and put full combustion pressure on the rings to help them seat quickly.
After the first 50 miles RPM is not a concern but heat will be for the first 1,000 miles. This all pertains to Gasoline engines.
Dielsel engines need to be loaded to seat the rings but it takes more load to do it on diesel engines. It is recommended to pull a trailer to help load the engine so the turbo's reach full boost and help break in the new rings.
On Class 8 Trucks, the big rigs, 18 wheelers, they are designed to haul 80,000 pounds and break in procedure recommends they hook up to an 80,000 pound load and hit the road to break in the rings. If they don't the engines use a lot of oil.
This is recommended to seat the piston rings so you get good combustion sealing and less blow by. Obviously if you see temperatures climbing while doing this shut it down and let it cool. High Temps can destroy your new engine quickly.
These notes are just addressing breaking in the piston rings. The rest of the car will need some pampering also to break in properly so read the manual for details.
Sean Michael
DFW
I think if GM wanted a break in period, they would have programmed that into the computer.
I bought a new Cadillac CT5-V and the digital guage cluster shows a reduced redline for the first 500 miles, there's video on the Cadillac forum of someone hitting 500 miles on the odometer when the redline immediately jumps up to normal. So GM can and does implement some programed break-in protocol when they deem necessary. I'm assuming GM would've done the same on other vehicles like Tahoes and Yukons if they thought it was import enough.
Smityinms
