It Rained so 2015 Yukon won’t start, Help!
Yukon2703
As always whenever we get wet weather our 2015 Yukon won’t start. The dash goes funky, all the warning lights, multiple service issues on screen like
-service airbag
-service trailer brake
-service steering column lock
-service front camera (doesn’t even have one)
Sometimes dash will go black like dead battery, won’t roll over at all then dash will go funky. Weirdest of all it will start off factory remote start on fob. I managed to get the scan tool on it and this is everything it gave me
Service steering column lock
Service airbag
Service front camera
C0110-61 pump motor circuit - stuck
Erased and all went away
U0140-00 lost comm with bcm
U0155-00 lost comm with IPC
U0170-00 lost comm with pass presence module
B2575-04 headlamps control circuit open
B2645-07 ambient light sensor high voltage
B2699-04 right headlamp circuit open
B305A-00 no response from steering column lock received
B3111-00 keyless entry transmitter 3 battery
B3935-00 transponder authentication
B3979-00 no environment identified received from hvac module
C0755-29 right front pressure sensor to few pulses
C0750-29 left front tire pressure sensor to few pulses
C0760-29 left rear
C0765-29 right rear
U0078-00 control module communication low speed CAN bus off
U0164-00 lost comm with HVAC module
U0208-00 lost comm with seat memory
U0236-00 lost comm with steering control module
Erased and all gone but
B305A-00 & B3111-00
U0029-00 MOST bus performance
Erased and went away
U0078-00
U0151-00 lost comm with inflatable restraint sensing and diagnostic module
U0155-00
U0184-00 lost comm with radio
U0198-00 lost comm with telematic control module
U0230-00 lost comm with liftgate control module
Erased all went away except
U0184-00 & U0230-00 stayed
This has been a major pain in the hole, I’ve seen many other write ups with similar problems but I’m yet to come across a fix, has anyone managed to find a fix to this extremely frustrating problem. Any help would be appreciated, doing everything I can to avoid a trip to hells gate (local dealership).
Thanks
PG01
Up here to the right
So, next time its dry for a few days and the truck is dry and acting ‘normal’ park it in the sane spot your issue happens when it rains then bust out your garden hose and try to wet down the truck 1 section at a time. Do the passenger side roof, windshield, hood and fender…. See if it starts, driver side …. Etc etc. but wait a day or two so that the trucks acts ‘normal’ and then do the other side.
my guess is you are getting water in the cabin under the dash or somewhere or under the hood to the fuseblock.
nicholsphillip41
