Jonas's 79' CJ7 Build.....
Yuko04
Yuko04
"SquareBODluvr"
MN
Getting it ready for,"FULL ROLLER" status!!
Maaaaaaaaaan! Did we have a hell of a snow storm in Wyoming on the way out to California and hit the same storm on the way home! Cost us 2 xtra hours on the road,but oh well. I am off for 10 days now. Just wanna update a couple of the fellas that watch this thread religiously:)
Started of by by putting the new outer 27 spline Dana 30 knuckles on with a Dana 44 ear to be able to run the bigger axle shaft U joint. Joints pressed in real good. Not sure if i am a fan of the little needle valve the use to grease them, but they will be fine.P4124818_zpsa1sgvymx.jpg
Now as you know, I kept the Dana 30 spindle because it is compatible with my conversion set-up. Although the brake calipers and brackets are not, I had to do a little trimming to the top caliper bolt hole and totally cut the bottom one off.P4124819_zps68tdvdi1.jpg
Bottom caliper bolt hole cut off so that the Dana 44 caliper and bracket can sit flush behind the rotor.
Now,since I am running a big thick billet wheel,There is no way the stock stud will even poke through enough to get a lugnut on. So I went with a longer stud that is intended for a dodge. Dorman part# 610-219 for the fronts. They pounded right in there and gives me about 1/2' more of threads.
New billet lock-out on.
I had to do some kustom cutting on the front wheel covers so the lock-outs could be exposed and accessible.
For the rear studs I used Chevy. Dorman part# 610-290
The shoulder had top be ground down to a taper towards the knurl.
Those gave me about 3/4 of and inch longer. Which gave me 18 turn before I hit 110 lbs of torque on the wrench.
I also went around and cut the existing U-bolts down to length.
*******FULL ROLLER*******
OOOOOOOO Weee, that front bumper height is sexy!!!:licklips:
Right on schedule and now I will load it up on the trailer, so we can head down to DCA FAB( 25 minutes away) to have a kustom drag link and steering arm made out of 7/8 chromoly tube:)
Happy Trails:favorites37:
Administrator
Awesome!!! :)
Yuko04
Yuko04
"SquareBODluvr"
MN
Thanks fellas!
Spose i better get the day started.
Im on "Phil" time today[emoji17]
Jiggy-J
Safetypup
