Jonas's 79' CJ7 Build.....
05alive
Masshole
Just read this whole thread and all I can say is "Wow!"
Your have some amazing skills. I can't wait to see this project completed.
And in keeping with the other posts...
GET CRACKIN' !!
Yuko04
Yuko04
"SquareBODluvr"
MN
Thank you sir. Still waiting for axles to get home. DCA Performance is backlogged and here i sit!
Jiggy-J
Yuko04
Yuko04
"SquareBODluvr"
MN
Finally Got the Axles Back
Finally got them back from DCA FAB. 4.10's are all set with the appropriate backlash. So I got started by putting the new diff covers on. No fluid will be added until I have everything mocked up and ready to paint.
I did the front axle first because I thought it would be the easiest. Well it would have if I was not shorted a pumpkinside 3" u bolt. The company shall remain nameless!
You can look at these HD perch plates and Ubolts and see why I did not use the stock ones. Some say overkill, I say "preventative maintenance"!
Now when you look at the pass side perch plate,you can see I have the outside Ubolt, but not a Ubolt next to the pumpkin. Thats because the pumpkin side runs a 3" 5/8 Ubolt. All the others run a 3"
Now on the rear axle I am doing a disc conversion. Lots of research. There is a kit for about $569. I aint paying that. So I did a K5 chevy bracket, 2001 Dodge 4x4 rotors and a Chevy 1 ton caliper. She will have NO problem Stopping!
I set the rear perch plates right away and cut the U bolts down to length.
Getting rear shock pitch and angle set so I can weld in the lower shock mount tabs.
Calipers set
STARTING TO TAKE SHAPE!
jdpber
GOLD MEMBER
The America
Great choice in brakes.
Nothing wrong with over building a off road rig as if it's attached it can break and will at come point lol.
Administrator
Nice!!!!
THE YETI
Director of Operations
South FL
Got the level 4 tune from PPEI locked into the Denali. Took it for a test run. She runs like a beast!! [emoji609][emoji100][emoji100][emoji100]
Yuko04
Yuko04
"SquareBODluvr"
MN
Safetypup
