Guy called me this morning to come get the trans......
Now.... the reason it took so long is that,
The bellhousing had multiple minor fractures ( so they had to find a donor)
Valvebody springs were all rusty and when they put fluid through them they just broke from being brittle.
They went through 3 pump bodies before they found one that would act right with the set-up I requested.
4 of the pan bolts that go into the tranny were either broke or stripped (so i would of needed a new case anyway).
The filter housing that goes behind the pump body had to be milled out .035 to accommodate the upgrade that the 84' 700r4 lacked.
So the end results :
New HD pump
Kevlar clutch plates
Advanced valve body to make torque converter lock up in 4th gear so no wiring harness is needed
Billet Vette Servo
New Case
1st,2nd and 3rd bands were hardened and shaved. Burning of the bands was a big prob in 83 to 85 because of electronic failure on Lock-up
@Jonah52 You still with me?
Now today, i will put the adapter kit on to hook up the Dana 20 Transfer case and mate all these components together!
GAME ON!!!!!!!
Jiggy-J
