Jonas's 79' CJ7 Build.....
THE YETI
Director of Operations
South FL
Looks great.
Wiping tears of joy from my face with $20s...
THE YETI
South FL
HAHAHAHAHA[emoji2]
Thanks Robbie.
What happened to the hundies? You ran out?
Jiggy-J
Nah. Put them back in the safe. We leave the 20s around the house for the kids to wipe their boogers on. Just happened to see one when I was reading the update.
Yuko04
Yuko04
"SquareBODluvr"
MN
[emoji23]
Jiggy-J
Pockets
West Ga
I'm feeling a little under the weather, can I come blow my nose at your house?
Sent from my V10 using Tapacrap
Yuko04
Yuko04
"SquareBODluvr"
MN
WELDING IN THE MOTOR......
Figured I would get this done today,because Monday,Tuesday and Wednesday are booked up.
Since most of this Install I will be doing myself. I like to use Mr. Hoist. He doesnt complain,***** or whine about doing too much work. He is always there to help...:Big Laugh:
Now the rear driveshaft will be custom built as will be the front. The rear will only be about 19" long with a double cardan joint on each end because of the angle and pitch.
The front will be about 3' long with a double cardan joint and a big slip yoke. Tolerances are critical.
A lot of measuring. You have to figure in radiator,firewall distance for dizzy and bellhousing and so forth.
I used this level as a reference, NOT a final determination.
Tranny has to level, motor has to be pitched to the rear at a degree for the TC tailhousing to line up and such an angle so there wont be any significant binding or vibration. I got my sight level out with the red laser and THAT gave me a good reference.
Trans mount and TC skid plate will be built together. I'll take the jeep out to my buddy Jordy's shop. he is a master tube bender and Buggy Builder. The skid plate and mount will be all tubular with some kickass shape.
Rear view.
Motor all welded in..
I left out a lot of the technical talk. Everyone does it different.
The Transmission and the T-case are supported by a rod and ratchet strap. Just secure enough for transit. Hope to have all that done next week!
Administrator
I support this message
Yuko04
Yuko04
"SquareBODluvr"
MN
Waiting for a friend of mine to get back from vacation, so we can make the transmission mount and skid plate. We are making it out "1 7/8 tube. He has a bender and know radius's and degrees well. So that's the hold up.....:(
quikdime
