Just Fishing
Can't fix stupid
Got the crank fully installed and torqued down after getting the bearing clearances nice and uniform.
used 600 grit on the bearing caps to help loosen it a tiny bit.
ended up with a nice .0015 - .002 (in) per the plasti gauge.
Factory Spec,
Internet seems to want .0025 +
but i'm guessing that's more for engines that are boosted.
So I worked to get that closer to the .002 for good measure.
Thrust bearing also has the classic mod to help lubricate the thrust surface.
New thrust bearing can be installed either direction (no tab), so lots of careful attention to ensue it's facing the correct direction.
and finally the thrust bearing clearance.
Illustrated above for the factory spec.
I got a nice .005 if I pry on the crank to ensure it's at the extreme compressed range.
then drops down to .0045 if I'm doing it by hand.
I do have the bearing lightly lubed with redline assy lube.
When installing, i followed the factory service manual where it notes to tap the crank in order to align the thrust bearing, then used a pry tool while torquing to ensure it stays there.
I got maybe another .0004 by doing that pry tool trick for some strange reason.
FSM instructions.
Factory Spec,
FSM instructions.
