Keeping coolant and transmission temps under control when towing in the summer heat
Geotrash
Geotrash
Dave
Richmond, VA
Hey Geo. Can you give us new guys a run down of your modifications? After 50 pages it is hard to keep track...
Thanks.
Sure.
Cooling system:
-Derale 13960 Hyper-Cool fan-forced transmission fluid cooler, mounted below the front bumper and plumbed in series after the fluid-to-fluid cooler in the radiator, wired into the fuse block using an add-a-fuse adapter on an unswitched circuit. Factory air-to-fluid transmission cooler deleted.
-Cold Case GMT569A aluminum double-row radiator. Had to clearance the top corner mounting brackets a few mm to get it to fit right. Also had to put a small restrictor in the small hose that runs from the radiator to the coolant recovery tank (I used a small brass fitting with a hole through it from the Dorman rack at Autozone that fit inside the hose snugly). I also had to trim the plastic factory fan shroud to account for the greater thickness of the Cold Case radiator.
-New GM 700w fan motor and matching blade from the K5L cooling package, installed in the driver's side fan position only.
By the way, I only just got the 700w fan motor and blade installed last weekend when I had the radiator out for the cam swap and that thing is noticeably louder when it kicks up to high than the 500w motor and blade it replaced.
As an Amazon Associate we earn from qualifying purchases.
RooTBeeRthe1st
But then you're introducing brass to your cooling system that already has aluminum and iron flowing through it.
I don't know metallurgy, but copper and aluminum don't get along, I would think that brass would be similar.
alpha_omega
Michigan
Brass and Aluminium can be in contact with each other without corrosion, so long as they do not have any additional items in the mix (i.e. steel, stainless steel or an acidic solution - NaCl or a water base with a pH greater than 7).
It’s not the two metals together that cause the issue, it’s the introduction of an additional metal or acid that causes a rapid often severe corrosion.
If you’re sticking with the brass cartridge, just keep an eye on all of your fittings.
