Keeping coolant and transmission temps under control when towing in the summer heat
Ok. Only the driver’s side fan spools up to a higher speed.
hm, not sure how you would troubleshoot that maybe check the resistance of each harness and both motors and see if one is different, on the 7/9 blade the motors are different for each side so the readings may be different as well
St. Louis
So for future reference I just measured the cfm of the 700w 7/9 rimmed blade (k5l) fans both sides measured approx 2300 cfm on high, measured inside the engine compartment right up against the fan, can anyone measure the dual 5 blade non rimmed 700w? You just need a anemometer
OK, I'm not sure if my readings are correct. I'm using the same model meter, have the same settings entered, and Don't have the K5L option, just the shroud #20923003 with the 5 blade rimless fans. They do get super loud on high and move a lot of air though.
My fans on low read 6600-7200 cfm. I didn't get a reading with them on high. When I first started the truck they were on high, but by the time I got the meter on and my phone camera on they switched to low. I even had the ac on auto and the temp set to like 62.
Here's driver's side fan
Passenger side
Passenger side
hmm, what do you get for a reading on the hvac center vent. fan speed on high, air setting for front only, recirculation on. once you have the reading going you can just press the hold button for a photo.
Tozan
Overlander
Yavapai Arizona
Well it took 2 nights of reading but, I made it... lol
I have the cold case in mine and I run a External 12" Transmission Cooler - Dual Pass that cold case sells.
My cold case internal cooler has a defective fitting so they sent me the dual pass cooler...
After driving an hour in 112 Phoenix weather It can hit 250 degrees but, on the highway it will hover around 225 to 230.
I once pulled a trailer in 105 degree and when running up a few hills coming out of Vagas at 70 mph it actually hit 280.
Thanks for giving me some ideas to think about reading your posts...
Geotrash
Geotrash
Dave
Richmond, VA
Are you talking transmission temps o_O? You definitely want a functioning oil to water cooler in the radiator for the transmission. An external cooler alone won't cut it.
1BADI5
DMV
This the fan shroud in my '10 PPv
madmombk
