Keyless entry
I have the window sticker for my 2001 Tahoe, it shows that it has “programmable locks”.
I am assuming that means it has Keyless Entry.
My in-laws did not get key fobs when they bought it new, so not 100% sure.
So I got a fob for it, but when I tried to get it into programming mode, I can’t get it to work.
Is there a quick way to look at either the fuse panel in the engine bay ir the drivers side to see if it’s actually equipped for it?
I have found that the receiver is in the dash behind the instrument cluster, but don’t want to dig that deep into it yet.
Any suggestions?
See if your RPO codes in the glovebox include "AU0"; that's the code for it in my '04.
01BlueTahoeGuy
I will look at the RPO codes and see.
There currently a few other electrical gremlins I need to look at, headlight switch isn’t working, the ac clutch won’t engage and the rear speakers won’t work.
Not too bad for a 20 year old rig really, I have seen a lot worse
S33k3r
Dallas, Texas
Experience tells me the headlight switch is probably dirty; you can take it apart, carefully and clean it. If you have another truck, borrow it's switch and check. Good luck on the other stuff!
BatsTDK
Orange County, CA
Are you having trouble getting the truck into programming mode, or trouble with the fob itself?
If you have an 01, make sure you have the correct fob. It should have “lock” and “unlock” words on the buttons, NOT lock symbols. Those are for 03-06 models.
01BlueTahoeGuy
I can’t get the rig to go into the “Program” mode to program the fob.
I don’t see AU0 on the RPO sticker.
Here is a photo of the RPO sticker as well a the drivers side fuse block.
From what I see, I don’t think it’s equipped with Keyless Entry. 40B399EF-D489-43EA-B38B-F49009020CAD.jpeg4C39D53C-A931-4D82-B075-23A6E3087131.jpeg
01BlueTahoeGuy
Decoded the RPO tag.
AE7 SEAT,FRT SPLIT,EASY ENTRY
AJ1 GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW)
AXP VIN IDENT POSITION, MULTI- PURPOSE VEHICLE
C49 DEFOGGER,REAR WINDOW,ELECTRIC
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS
C7K GVW RATING 6500 LBS
DE2 MIRROR,OUTSIDE,LH & RH,DIRECT CONTROL,FOLDING,PAINTED
EVA TEST DVT, EVAP EMISSION REQUIREMENT
FE9 FEDERAL EMISSION CERTIFICATION
FF6 ARM,TORSION BAR SPRING ADJUST,LH
FF7 ARM,TORSION BAR SPRING ADJUST,RH
GU6 AXLE,REAR,3.42 RATIO
JAN PLANT CODE - JANESVILLE, WI, BOC
JC5 BRAKE VAC POWER, 4 WHL DISC, 7,200 LBS
KG8 GENERATOR 130 AMP
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC
LR4 ENGINE GAS, 8 CYL, 4.8L, MFI
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC
NF2 EMISSION SYSTEM,FEDERAL,TIER 1
QNK TIRE ALL P245/75R16 BW R/PE ST TL ALS 109S
R9H
SLM
UM7 RADIO,AM/FM STEREO,ETR,CLOCK
UQ5 SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL EXTENDED RANGE QUARTER MOUNTED
UY7 TRAILER WIRING,7 WIRE,2 LEAD FRONT HARNESS,5 LEAD REAR HARNESS
VB3 BUMPER,REAR STEP,INCLUDES IMPACT STRIP(CHROME)
VG3 STRIP,FRONT BUMPER IMPACT
VP6 NOISE LEVEL CONTROL
VXS
V54 CARRIER,ROOF LUGGAGE(PAINTED)
V73 VEHICLE STATEMENT - US/CANADA
XNK TIRE FRONT P245/75R16 BW R/PE ST TL ALS 109S
X88 MARKET BRAND CHEVROLET
YD3 AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE
YD6 SPRING,REAR(BASE EQUIPMENT)
YNK TIRE REAR P245/75R16 BW R/PE ST TL ALS 109S
ZNK TIRE SPARE P245/75R16 BW R/PE ST TL ALS 109S
ZQ1 CHASSIS PACKAGE SMOOTH RIDE
ZW9 BASE BODY OR CHASSIS
ZY1 COLOR COMBINATION SOLID
1SA SALES PACKAGE
1SZ PACKAGE OPTION
12I INTERIOR TRIM GRAPHITE
12V TRIM COMBINATION VINYL, GRAPHITE (V) (99)
39U EXTERIOR COLOR,PRIMARY,BLUE METALLIC
6XK SPRING COMPTR SELECT FRT LH
7XK COMPONENT FRT RH COMPUTER SEL SUSP (7XK)
9X5 FRONT HIGH BACK BUCKET SEAT(CLOTH TRIM)
https://rparts-sites.s3.amazonaws.com/dec399b0838336997484042ed2af1004/design/rpoCodes.pdf
BatsTDK
Orange County, CA
Just to confirm, are these the instructions you’re following?
01BlueTahoeGuy
Yes, I have tried multiple times using directions, but could not get into tje programming mode .
pugnaxx
