Knock sensor P0328
J
jetson22
Anyone have a pic or diagram of where the bank 1 knock sensor harness leads to?
tooleyondeck
Northwest FL
The sensor is in a bad spot to get to.
Just be glad it's not a GMT800 lol
Your knock sensors tie right into the main wiring harness, so if you want to trace the line to the ECU you will need to cut a lot of wire loom to track it. I would start with AC Delco sensors first.
You could always tune out the error codes, if you like to live on the edge...
J
jetson22
Thx for the reply. Does anyone know the part number for the AC Delco harness? RockAuto doesn't carry it. On their site it says the AC Delco sensor mates with PT2652 but when you look that up it says doesn't fit your vehicle. RockAuto carries a Standard Motor Product brand of connector.
J
jetson22
Sorry for late update. The place or person that did previous maintenance on the vehicle did not do a good job. The motor mount was replaced but was not tight and they pinched the knock sensor harness wire. I installed a new one and now that problem is solved. Thanks for all the help here!
Boyce0183
