ScottyBoy
I just did mine last week. I have heard on another forum that it is imperative to torque the knock sensors to EXACTLY 15ft/lbs , no more and no less. If torqued more than 15, it will be overly sensitive and give you a false knock sensor trouble code. I suspect that this is what your issue is. I had to actually go out and buy two torque wrenches when I changed mine. Luckily, Harbor Freight was having a Father's day sale and had them on sale for only $10 each!
I would get a 1/2inch drive torque wrench that will read 15 ft/lbs, and pull the intake back off and redo it. You should be able to reuse the intake gasket since its new, and just redo the RTV sealant around the knock sensors.
