LED DRL Questions
vt_hokie2008
VA
I got these for turn signals: http://www.v-leds.com/5K-TYPE-2-DUAL-COLOR-p7114832-1-2.html
These resistors should stop the hyperflash: http://autolumination.com/equalizers.htm
Scroll down to Load Equalizers, I have 6 ohm, 50w, though I hear 25w works too.
I bought these for the DRLs: http://www.ebay.com/itm/130771504496?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
And two of these: http://autolumination.com/equalizers.htm
Scroll down to LED Protectors
I will admit that some of this is on the way to me and not installed, so if you wait a bit I can let you know how it goes. Currently I have some cheap switchbacks from ddm that aren't working so well (flash 5-10 times for signal and then just turn off) and I've blown one of my DRLs already, so I'm redoing all of it.
2010_5thgen
I can hold off for a while. Let me know how those turn out for you
Fast55
Ventura County USA
I've had V-LED's in my DRL's for at least 2 years now with no protectors. I think the '09's did not turn on until you put it in gear though.................
Modded
That Guy
Yeah I think that feature started in 08. I drove an 08 as a lender for a few days and the DRLs were like yours.
2010_5thgen
is there an easier way to get these DRL and turn signal bulbs out, other than taking the bumper off to get the headlight out?
vt_hokie2008
VA
I take enough loose to pull the top of the bumper out a bit, I don't actually take it completely off, then take the headlights out. I haven't figured out a way to do it otherwise, especially since you're going to have to do some wiring work for the switchbacks.
2010_5thgen
wiring work? what? i thought i didnt need anythign for the DRL's?!?! and i thought the turn signals just had rapid blink?
Dabney83
