babamerino
can can get the rear 2 inch springs. If you have higher mileage id do the rear shocks and springs at same time.
2011 with 30,000... So just the springs? You sell these? Thanks!!!
I have customers who tow a lot and the same kit ran for years no issue. Aitoride truck with 2 inch sorings and no spacer means less air in bags which leaves a really soft ride. The lowered spring with spacer and links adjusted is more air in bags making a more responsive ride.
I tow my ctsv to street races almost every weekend. 5 people in truck and at the 4 inch drop I have now there are jno wear issues or bags being blown and this is over ine year of using it.
Now ive also had trucks that gm used oem taller springs tjat I adjusted the rear and sat almost even with stock springs. Pm me for info on that
---------- Post added at 11:27 AM ---------- Previous post was at 11:26 AM ----------
Sidenote I hate typing onmy phone
why spend 225 on springs only belltech where 250 comes with springs/spacers and shock extenders.
Use the belltech kit for 250 i have
use the 1 inch spacer
set the rear links to 3.5 inches
done
---------- Post added at 10:37 AM ---------- Previous post was at 10:35 AM ----------
if you only want a 1 inch drop you can get the springs for 225 and go to hardware store and get 10x24 machine screw set it to 3.5 inches and will get that 1 inch drop. Anything i deal with autoride trucks i always use shock extenders just piece of mind.
