Leveling kit with magnetic ride control
01Konvict
Boats n Hoes
Raleigh/SML
No point putting it on the back when the rear height didn't change at all!! What a dumb a$$! It goes on the front so the level arm is set back to normal position to trick the computer so that the shock is set to normal. Putting it on the rear only increases the air shock to inflate more causing it to raise up but without the front sensor kit it will ride like crap cause the sensor position is off. Go take it off the rear and put it on the front and tell the shop their morons.
noharleyyet
Sensors front and rear. If you change either you must install the brackets for sensor arm compensation.
Todd Staker
I would like to see some pics of newer Tahoe 2015-16 with front leveling lifts. Also, please list tire size. Thanks
IamZ
Just installed the SuspensionMaxx adjustable leveling kit for my 2016 yukon xl denali. Looks great! Rides smooth as ever! No problems so far. I'm getting new wheels installed tomorrow so I'll take some pics then...
WillieFlo
Houston, Tx
Todd,
Here's mine with 305/55R20's.......the only thing I will change is going to Nitto Ridge Grapplers next set.
full
full
Dark Star
I was thinking of going with the ridge grapplers too. Let us know what you think of them.
Chadly14
