Please get some pics of what your wheel wells look like after the trimming, it’s remarkable you could get that kind of offset working on a 3” lift with 33’s let alone 35’s. I give you a lot of credit, this has to be a lot of
It really didn't take much effort to make them fit. There was a lot of non-visible plastic material shaved off from the inner front bumper to maintain my turning radius, but it's behind the fender liner, so you wouldn't see it anyway. After that, I pushed back the liner further back and zip tied it.
As for behind the wheel near the doors, about an inch of the outer sheet metal was shaved off, and a bolted metal bracket was also removed. Attaching the inner liner was a little more challenging to attach, but I made it work. Lastly, the power running board was moved back two inches to eliminate any further rubbing.
It's not everyone's cup of tea but performance-wise, it handles remarkably well on the road for an SUV, and has a very solid feel behind the steering wheel. The wider tires and stance also help tremendously with the braking (I upgraded to 8-pot Brembos) and cornering, and I've had zero issues with any rock chips on the paint. I occasionally get tire gel "sling" on the paint after detailing the wheels, but it's extremely minor now that I've switched to the foam tire detailer...
When it comes to curbs, I was initially paranoid about curb rash but I've grown accustomed to my boundaries. I've equipped two small blind spot mirrors on my side view mirrors and positioned them to view each rear wheel. This helps if I cut a corner too short, or with parallel parking - which hasn't been a problem either.
If I had the choice to do it all over again, I wouldn't hesitate.
