Lifted/Leveled 2021 - Postem Up
Morales1995
Well the only way to get a thicker side wall is to downsize the wheel or upsize the tire.
I’m thinking going down to 18 but I haven’t seen any with that size wheel and a 3.5 suspension lift :( feels bad. I also haven’t seen any with the 3.5 and upsized tire for that matter. It’s all too new we are pretty much setting the foundation for a lot of folk lol.
sanman28
Wide tires isn’t my thing I prefer more or less flush to the fenders but I do like a thicker sidewall but from what I’m reading that can’t be achieved with 20s
Nitto, for example, has 50,55,60, and 65 series 20” rubber in their TGG2 tires. A 65 series is more than a little bit of sidewall
sanman28
My expy max on 3” with 17” wheels and 295/70 rubber
olyelr
Elk Rapids, MI
Thx. It’s been great. Transfer case sucks is the only downside. No 4H. Only 4A and 4L.
Ooooof. Well at least there is low range.
My wife just had her ‘22 high country in for some minor body work, had a new expy limited as a loaner. She hated every second of it. Couldnt hardly stand it. I told her it is better than a prius!
R32driver
I’ve never had a ford but they sure are nice looking rigs. Them superdutys blow gm out of the water in the looks department
Jgrimberg1979
Looks good
Just got my nitto ridge grapplers mounted 305-45-22 and I definitely like them. Haven’t notice any rubbing yet. It rides well too. The only con is the tire noise which was expected. Should I use the same tire pressure as the stock 285-50-22’s? Asking because obviously they are some big tires. They look really good when I have my air ride up one above normal. I will be installing edgymod links so it stays up that high all the time
Do you know the ride height increments that the air ride has stock? Like first setting 3rd setting (one up from normal) is 1” 4th is 2” or is it something different stock?
Thanks again for the help!
olyelr
Elk Rapids, MI
Looks good
If you are asking me about the air suspension, i have no clue. The wifes dosnt have air ride.
How about some pics of those ridge graps!!?!
Jgrimberg1979
I will but it was nasty out today. I will post an update after a day of driving them tomorrow a lot with them on.
KarlG
