Lifter tick ?
I have been noticing lately that when on start up I hear the dreaded lifter tick.
I'd say within the last year I've heard it more during the cold weather and it would only last seconds, not even a minute. Rarely during the summer months.
Now(within the last 3 or so months), its seems to be happening more often and for a lot longer, at least a couple of minutes.
Seeing that it does go away relatively quick, I'm hoping I don't have to start worrying.
Cant really say I'm prepared for a DOD delete right now but am hoping it'll survive a few more months.
Is this a crap shoot or what? What should I do?
Sucks because I just got the last of my parts for my exhaust and I wasn't expecting this to be happening so often.
Mine ticked for a couple of seconds ever so often. Not at every cold start, probably 4-6 ticking "spells" at startup over the course of a 5K-mile oil change interval. Like Ken, I bought mine with just under 150K (146K) and it's now a few miles from 190K. I'm sure the PO used conventional oil, but I use synthetic exclusively. The first couple of oil changes after I bought it, it had fewer and fewer ticking spells. By the third or fourth oil change, the spells had ceased. I attribute this to the cleaning agents in the higher quality oil gradually removing small amounts of sludge in the sensitive AFM lifters.
I'm going to check the oil after work when it cools down. I'll look at the oil life gauge and see where I'm at there as well, been pretty religious about changing my oil. May have to start doing it more often.
After I change my oil, I'll see how it goes. Then I'll give the additive a try.
214k a lot hahaha
Runs great though, other than the tick at start up.
I wouldn't trust the oil life monitor. I stick to a 5,000-mile schedule because that's a good time to rotate the tires so I handle it all in one shot while it's up on jack stands. If I went by the monitor, I'd have 15K-mile OCIs and considerably dirtier oil, which is likely to lead to some build-up of crud and return of the lifter ticking.
I hope you drive for a lot more than 2.5 miles at least a few times a week. That's not enough to properly warm up your engine and oil (especially during the winter months). This, coupled with too long of OCIs, can greatly reduce your engine's life.
What oil do you use? I agree with the other knuckleheads about using a REAL cleaning additive. Clean out the sludge and note any changes, stick to a regular OCI more realistic than what the OLM tells you and use a quality synthetic oil. And drive that thing more than just 2.5 miles after a cold start twice a day. The engine needs the full heat cycles to burn off the water vapor that builds up in the crankcase as well as to prevent sludge.
shannan kinnaird
09 chevy 5.3 4wd was diagnosed to be valve spring on #4 cylinder. changed spring & retainer (i noticed when removing rocker arm that it wobbled/slack in it/too much play and at that moment i knew it was misdiagnosis on spring). replaced it anyway and still got tapping noise. truck sounds little better but not fixed. ive thought about buying lifter, pushrod, & rocker arm and trying that route. any suggestions would be greatly appreciated. truck been down toooo long and my better half is working out of my explorer and its slowly going to shit......help anybody
Woodblocker55
Everyone checked for cracks in exhausted manifolds right ??? Bolts gone or broke .
Mine it's exhausted manifold sounds just like a lifter tick till it warms up . There is 2 broke bolts on back driver's side manifold . I put clamp on till I get chance to rip it apart.
Sent from my LGL722DL using Tapatalk
Foggy
KS
IF you are going to do 1 lifter... do them ALL
The cylinder heads have to come off to access the lifters..
Do it once, Do it Right !!
SinStar999
