thompsoj22
- Joined
- Jul 21, 2018
- Posts
- 689
- Reaction score
- 718
Thank you.
Yeah I spent the extra money on "GOOD" parts to avoid this crap.
The truck runs great, it's very fast for it's size nearly in the 4's 0-60 which is insane. But my primary use for this truck is a cold start, drop son off 10 mins away, back in the driveway. It won't quiet down until I am about to shut it off for the day.
Here it is completely warmed up and it sounds perfectly fine.
If it were me, My first swap would be the "HI PERFORMANCE" springs for oem's. Eliminate the static downforce which is probably collapsing the lifters as it sits overnight. This can be done with the compressed air technique or a tried and proven method of bringing the piston up about two thirds of the way, Feed 3/8 nylon rope into the chamber through the sparkplug hole until it stops, Then bring the piston up til it is firm and stops. You can now compress springs remove retainers and swap in oem and retainers, Then rotate the piston down slightly and remove the rope and on to the next. I swear this works fantastic, The reason for the nylon rope is no fibers from other choices like cotton/hemp.
