Lifting a Denali / Magnetic ride suspension?
DWSmoot
Charleston, SC
Mainly interested in getting somewhat larger tires, say, +1-2 inches in diameter. Can it be done while still keeping magnetic ride?
What is your current tire size? A 2” diameter change could differ greatly than 1”. I have a Z71 and added a 1” strut extension up from. Running a 33.5” tire with very slight rub in reverse and full turn only. If you go any larger on a tire you will need to do at least a 3” lift. I have done quite a bit of research. I don’t have magnitude so can’t help there, but this info above should help on your decisions for tire size and needed lift.
Artem-G
Artem-G
Vancouver, Canada
The 2021’s run on 32.8” tires stock. I am currently running on 275/70/18 — that’s 33.2”
Looking for a setup that would enable something like 35” or whatever’s possible without affecting the ride quality too much. Would leveling alone allow for any larger tire size?
FWTXAT4
